Identifying model New Holland running gear
Steve in VA
I don't find anything in archives so here I go. Picked up a hay wagon w/ New Holland running gear. I don't have a picture to post. How do I identify the model so I can reliably get any bearings, seals, and such that I may need in the future? Is there a plate somewhere? I haven't found any markings other than the NH name on the axles.
Thanks in advance
Should be common bearings,seals,etc. Any parts store can supply. Just take the old parts in a sample. No need to spend double at the dealer.I'd bet a hundred dollars it is the same bearings in a different box.
Take any hub off, clean it up, and bearing/race numbers are likely to appear. If not, disassemble and check backside of races...or measure at parts house, order a set.
