ID this plow
Dralon
Good morning, somebody sent me a picture of a plow they are selling. They say it's a Massey Ferguson and that the cutting width if 16" which i doubt very much. Can someone help me id this plow and if possible tell me the max cutting width
For cutting width measure the distance between the centers of each curved plow beam or easier is to measure from one side of beam to the same side of next beam. Also one can measure rear RH end of share to rear of landslide on same bottom.
They are talking 16" per bottom. So your total width is 3 X 16 or 48". Massey Ferguson is believable as it looks similar to Ferguson plows but I am not a expert in the fine
points here.
Do want to alert you here though. The Lathes are missing on this plow and are necessary if you want to put it in the ground to work. Not sure which style it uses but the older
style IF available are spendy.
jt
Sorry i badly expressed myself i meant they say it's a 16" furrow, like i said the pictures makes i seem like it's a 12" or 14" I have 18" tractor tires so i would not go under 14" furrow
I will look more closely about the Lathes when i go see it and the rain stop. If anyone has more info or helpful comment i will gladly like them. I am a new very small acreage farmer willing to learn everything i can
