Hydraulic Adjuster for 3 Pt Hitch
WNYBill
I would like to replace the crank lift arm adjuster on tractor 3 pt hitch with a hydraulic cylinder. Cylinders are easy but the yoke to fit over the lift arms is the problem. I have been unable to find a site that sells different sized yokes to screw on the threaded end of the cylinder.
I realize there is an after market complete kit, but they are pricey!
Bill
Considering it just for max up/max down operation, or setting depth and attempting to maintain it with some degree of accuracy?
I am just tired of getting on and off the tractor to adjust the back blade. Often want to change the tilt for just a few feet while grading roads. Blade has power angle so I know how great power tilt would be!
I have looked at the aftermarket, 4-500 dollars when all you need is a cylinder and a custom yoke. There has got to be somebody that sells custom yokes. I also need a longer yoke to extend the lift 1 or 2 inches on a 8 foot trailer mower.
Bill
(quoted from post at 08:16:21 10/08/16) I am just tired of getting on and off the tractor to adjust the back blade. Often want to change the tilt for just a few feet while grading roads. Blade has power angle so I know how great power tilt would be!
Bill
Yoke would be easy to make.
I asked because I tired one once and resetting your sweet spot after a lift and having it hold a tight dimension when the hyd oil got hot and it extended on it's own were problems for me so I just went back to manual adjusters.
I guess, if you had a machine shop. I can't weld cast and have no way to drill 1 1/8 holes. Seems like somebody would have custom yokes.
