What model international is this?
2150man
I have a two row planter that doesn't have a tag on
it and I would like to buy some more seed plates for
it is there a serial number stamped in somewhere
249-250 but any seed plates fit, Just get the plastic and all you need to know is size of seed you want to plant and number of cells if more than one number of cells are avaible. The 4 row version is 449-449A or 450 and with clutch lift are in big demand by the Amish. Only 4 row clutch lift planter that can be set to 30" rows. Most parts for yours will interchange with the 4 row model.
if it is a straight drill planter its a 249, if it is a hill drop its a 250. if you look on Ebay, there are are often farmall planter plates listed. Also, look up Lincoln Ag supply, in CO. they are the makers of the farmall plates. good people to do business with. i sent them 3 samples: yellow dent, purple hull peas and blue lake green beans seeds and they e mailed what plates to use.
bass
