Zachary Hoyt
I just bought this at an auction for $428. I had been looking for a 6 foot rotary cutter to use for cutting weedy fields and such, but I bought this instead since the price seemed right. There is a plate on it with a serial number, marked Hecho En Mexico, but no model number. I am wondering if it might be an older 25a since it is 6-1/2' wide and seems to look somewhat like the ones I see in pictures. I am planning to run it with a Farmall 300 and hoping it will have enough power. The belt looks nearly new, but many of the hammers (if that's what they're called) are a bit beaten up. The auctioneer said that it had been gone through about 6 years ago, before it was purchased by the late former owner. I have never run a flail mower and I am wondering if there are any words of wisdom about what to do and not do. I know they don't like rocks, but the areas I will be cutting should have few if any as I have been being mowing them regularly once a year for the last 15 years. I can see some grease zerks and will make sure I grease it before I put it to work. I cut a test swath with the Massey 35 in the yard by the sawmill and it seemed to work OK, but that grass wasn't that tall anyhow. Thank you very much for any advice.
Zach
Zach
