nh 489 hay conditioner
farm-al
I am needing a bolt or pin ( it's missing) that connect's the sickle to the drive arm I have the bushing that has the " C" clip,I bought this old machine this summer and it is in need of some repairs but it is in usable condition,thank you,Al
Here's what is recommended for the 489 in my manual.
Also don't run the wobble out past the shield to put the bolt in, run it till bolt goes in through the small round hole, otherwise you over travel the rubber in the bushing. Run the machine for a half hour or so then re-torque the nut. Also be VERY attentive to the reel drive chain that drives off the wobble box. If the chain gets loose enough to jump the sprocket it almost always breaks the shaft and that means new a new gearbox.
