Tx Jim
- Location
- Coyote Flats, Texas
This is the 1st time for this problem. I have an '05 JD 467 rd baler that baled 22,450 bales. It only has 3 or 4 missing/broken PU teeth. Belts were replaced with new belts in the Spring of last year and have about 3200-3300 bales on them. I was baling ""unconditioned Johnson grass"" as I only have a disc cutter(no crimper) and as moisture/humidity got lower baler began to easily plug before starting the core. If I slowed rpm's to idle sometimes it would start core,sometimes it would plug. I then asked my neighbor whom own's a similar 467 that he just bought with bale count unknown because original monitor was stolen from from out of seller's tractor cab while parked in hay field. Long story/short his baler never attempted to plug even at pto speed.
Thanks for any ideas,Jim
