Working on my backup baler, could not figure out why the Twine finders were not coming back to home after attempting to
tie a bale, which nothing is tying. Found that the Cam is "Turning" on it's own and is not going to the home position,
causing nothing to tie. I verified it does not move on my other baler or on my parts baler. Has anyone taken this
apart, if so, what is the best approach to removal and fixing this problem? It appears there is a key in there, likely
broken, and it clearly says in the owners manual, that the Twine Finger Cam Held to knotter shaft with "Locktite".
Anyways, I am sure others have done this procedure, just hoping to get some help before I start tearing things apart.
The baler worked great right up until it didn't, hoping i do not have to re-time everything just to fix this part.
