Anyone running their haybine in the locked-up position for the purpose of clipping their fields before winter?
I can lock my Hesston 1110 in the up position via a pin, yet still have it in the open/field vs transport position. Outwardly I don't see any driveline extreme angles that might cause a problem?
It is so dry here that I don't want to clip my fields close with a sickle bar mower or with the haybine in the down position (5 inches is the setting height). I'd like to leave as much height and green leaves as possible for fall recovery/regrowth. The goal here is to trim cut above the dormant Timothy and nix native weeds before they go to seed.
I'd use a 5ft bush hog, but thinking the 7ft haybine would be a much faster and cleaner cut.
Anyone use their haybine in the up position to clip their fields?
Thanks!
Bill
Thanks!
Bill
