Still needing parts for D-EO-20 MF hay rake
Farmallb
Im still looking to find
2 doz rake teeth
2 rake teeth bars
1 doz rake teeth holders
both star wheels
a end piece star wheel cup.
(quoted from post at 15:48:18 09/07/16) Im still looking to find
2 doz rake teeth
2 rake teeth bars
both star wheels
I've got to get my parts book out and check to see if my reel bars will work with yours. They made several revisions of that rake down thru the years and not all of the parts interchange even though the rakes look identical. There were three different versions of the teeth but all the styles of teeth are still available new.
And the teeth are specific to the serial numbers of the rakes. I just can't remember if the reel bars changed with the teeth. I'm almost positive they did.
I had one here for several years. Used to buy the teeth at the local Farm and Home. A few years ago you could still get the clips and teeth at Agco. I needed the big pulley and found out it was N/A. The small shaft in the star cup that the bar rides on could still be had for $100.00. There is also a small bearing in the bottom of the cup that the shaft rotates in. The parts person did a search for a bar. Found one in Kansas.Cost $450.00 .That was 7-8 years ago. If I remember right , there's a rubber grommet that goes between the flinger and the bar that's pretty important to avoid wear in the metal parts.
The bad thing about the rake was it's only 8 feet wide. And in ropes really bad. Good Luck.
2 doz rake teeth
2 rake teeth bars
both star wheels
The bars I have should work with yours but I'll be honest, for what it would cost to ship those heavy cast stars and stuff you could probably buy another rake.
I CANT FIND ANOTHER RAKE. Ive been looking all over. I told my boy who is as tight as McDuck that the parts would be easy to find, as Ive been using antique equipment all my life and have a pretty good source of places to look for parts, but I cant find NOTHING for this rake. Hang onto your bars. IF I cant find at least the back tar wheel, OR even one end of either, it wont matter. One of the star wheels he has has been welded, as the end had broken off and somebody welded it back on. The end one also has been welded on at one point, but one end is missing and gone.
I replied to you on the MF site that you can buy teeth easy at TSC or MF dealer. Take one of the teeth off and bring with you to store to be sure correct match. But for other parts also try NOLT's Equipment in PA for used parts, phone#717.776.6242
