Pulling the sickle and guards from my Hesston 1110 today. Afterwards will be giving the swaybar drive mechanism a thorough inspection for play. Got a significant amount of hammering/noise from the mower - IMHO an unacceptable amount. Got rid of some of it when I retimed the rollers and set the roll contact gap so the rollers never touch. I'm thinking with the sickle absent from the machine - this would eliminate all sickle hammering noise potential and leave the sickle drive to make any noise. I think it's all in the sickle, but there might be worn bearings, adjusting of slack in a couple of areas that might be causing a racket and need adjusted.
When I was a boy, I saw a guy remove a lawnmower blade from a push mower. He started the mower and promptly knocked a hole in the block. In my mind, the sickle is the flywheel - just as the blade is for a push mower.
Run at idle without the sickle or don't?
Thanks!
Bill
Thanks!
Bill
