Brush cutter
JoeK1975
New User
My tractor has a 45 hp engine. The pto rates at 38 hp. My question is will a bush hog with a gear box rated
at 40 hp, will my tractor work with this mower? Thanks in advance for your responses.
Yep. be fine. If your tractor does not have 'live' pto,you will need to purchase an 'overrunning clutch.What tractor?
Should be able to handle a 6' Bush Hog...be SURE to use a Slip-Clutch on the PTO and be SURE it will work..
Your choice about the ORC...I prefer NOT to have one and be able to STOP the Mower, but most opt for it..
A lot depends on the Tractor AND the Operator, whether it is a nuisance or a Blessing...!!
