Chris NW Ind
Got this yesterday for cheap. Works pretty well as the seller demonstrated before I bought it. Right off I realized it isn't a FH mower exactly meant for the Super C (even though it was advertised for the C, he had it on a 240 utility.) Nevertheless, with minor adjustments it easily mounted to the C. I think once I understand the linkages that control the lifting and levelling of the bar, I get her squared away. The seller forgot to give me the manual but is supposed to be mailing it.
I have 2 questions:
1} Does anybody have any guidance how to setup he levelling/lifting linkages (or whatever they are called)? I've seen some pictures that have a rod leading to the touch control arm.
2) Is there a good way to straighten the bowed cutting bar? Some blocking and weight?
Thanks, Chris B.
I have 2 questions:
Thanks, Chris B.
