hesston pt 10
been a while since I did one, your pitman drive arm needs to be unhooked at the pulley and the is a spring loaded pulley at the top front that puts tension on the belt. I had one of my boys hold it back while I put the belt on. also they made some changes to this the newer ones of the PT 10's had a different tension set up on them that was a simple set of rods you ran the nuts down to relieve the tension. I have mine in the back of the shed a spare unit, they are good moco just getting old.
