Implements and Parts FARMALL SUPER A
It appears from looking at other Farmall tractors A's and Super A's I am pretty much stripped between the rear tires.
I'd like to find the parts so I would have a lift of some sort using the hydraulics and looking for A two bottom plow and a disk.
Thanks
FRB
I think unless your soil is real sandy you better be looking for a 1 bottom plow. I know that is what the A is rated for since I have a plow that came with my Farmall A or should I say what came with the broken A that I used to build my BA with
There several aftermarket 3 point hitch 'kits' available for your tractor.YT has one listed for $616.00.If you have any 'iron working' skills you can make your own.old is right,a one bottom is all that A will want. A 3point mounted will be acceptable.However,you will need some kind of depth controllng 'device. A set of chains will serve that purpose.If this wont work....sell the SuperA and buy an 8N or similar
