Trying to find tires for NH 469 Haybine
Brett24
I had a sidewall blowout on one of the tires on my NH 469 Haybine. The manual calls for a 7.5x14 flotation tire. I can't find any.
Is there a place that still sells these?
Is there a reasonable substitution?
Brett
Any 14 or 15 inch tire is getting hard to find. I have 165/80R-15 on my NH460. So if you can find an old car or truck tire in the 165-195 80-14 you should be good to go. I git luck a tire shop in town had a brand new 165/80R15 in stock and sold it to me for $35
I had four nearly bald tires from a Scout I was keeping for hay wagons. Got a flat on my 1207 so I put two on and they were too big to clear the axle. I had to saw off the corner of the tread. Works but if I set it to cut low the sheet metal contacts the tire and will not go all the way down.
