IH Sickle Mower Model Help
SaveMy50
Can someone please identify my model. I tried using the Case IH site, but nothing seemed to match. I have an older (I think) similar model that I grabbed the pulley drive housing from (broken main nut). This mower seems to run fine, but also lags a bit, not sure how to adjust, so i'll be grabbing a mower once I can identify.
I have one just like that, it is a B23 mounted mower made at IH works at Doncaster UK. When I left school in 1958 I worked
at an IH dealer and we sold a lot of new ones. In the 1970s I worked at another IH dealer and sold 2 of the last batch of
these mowers made. MJ
It is C-28 mower, pull type is a C-32. I did not see a listing on the parts site either, but a dealer will have more information.
I have one that looks a lot like that but is not a 3 point hook up. The one I have was made to be mounted on an A and I have it on my BA which is half B and half A
I have one also. It is a U-F28. It is suppose to be used on a 300 utility. I made a bracket for it and I am using it on a Super C with the fast hitch. It work really well as I mow pasture with it. I got an operators and parts manual from Binder Books. Some of the parts are still available from Case/IH. All you need is a deep pocket. If you need parts for it, post it on this page and someone will know where it can found.
Unfortunately the dealer has not been able to confirm the model yet. I don't think it the U-H28, pictures on web show that model with quick release (front forks?) not a 3-pt hitch. Only 28 manual is saw was McCormick, but no pic, maybe i'll have to call the vendor? Appreciate any more comments. I need to adjust the bar floatation, it's tense and it rises on minor bumps.
