Revisiting a well worn topic - tires for implements, mostly wagons, but lets also say semi mounted plow, transport disc, rakes, and so on.
If you did not use your implement hard and were looking to 'save a couple bucks" and go the used route, would you be on the lookout for tires in the following order:
Bottom of the food chain- used light truck tires. Is there anything "lower" than used truck tires that are serviceable for implements?
Next up - Used trailer tires. these are usually designated with an "ST" in front of them.
Next Up - used genuine implement tires
Top of food chain - used aircraft tires, if you ever see any (I don't).
