Frick thresher in action. How do I adjust it?
look at the straw before the blower to see if you are threshing it if you are then open the sieves or close down the wind, might need to do a combination of both, if you aren't threshing it you may need to add another set of teeth if it's a spike tooth, if it has a big pulley for a 2cyl. jd it will run too slow if powered by a 4 or 6 cyl tractor as belt speed is faster on a jd
