I have a question....got an old JD running gear and we cleaned it up and painted it. The old wood was so rotten and we started this project a couple years ago that I can't figure out the best way to put it back to together. I have the old stringers that are 16' 2" but need to cut back about 2 feet on each one to make it work. They are rotted on the ends.
The wood is what??? So heavy and can't imagine the cost to replace. Seems like 3 inch x 8 inch rough cut. I bet each one is 250 lbs. If I cut back then I need to re-adjust the gear. I'm thinking about 2 feet front over hand and 3 foot rear overhang. Is that pretty normal? I hope to hold 100 bales still.
Also, how does the wood frame stay on? Looks like the old wood had just one bolt and kind of wedged into the vertical braces off the gear. Is that normal for roll so it's not so rigid?
There were two wooden braces between the stringers. Looks like those were not over the axle. Is that normal too?
thanks, Mike
thanks, Mike
