New Idea Rake-Tedder
Jim Wolf
I have a No.4 rake-tedder. Between the two bearing caps there is a grease fitting. Sometimes the shafts (tooth bar) is turned such that you really can't get a gun on the grease filling. In some cases I can turn the shaft just enough to make the fitting accessible but other times not. Is there a trick there that I am missing?
