showcrop
My MF 224 which I just had the plunger head out of to adjust the knife to knife clearance now has a distinct thud on every stroke, just as the plunger head STARTS TO RETURN. Of course it has ALWAYS done this to a degree, but it is more noticeable than before I had it apart. all of the connections are TIGHT. NO DETECTABLE PLAY ANYWHERE. I have ROLLED it OVER by HAND. There is NO DETECTABLE SIDE to SIDE movement. The clearance knife to knife is set at the upper limit. I have just finished baling 480 bales with no problem, but every time it is running with no load I hear the thud thud thud. Ideas? By the way, the crop in the last field was 30% over expected, and I ran out of twine. When I went to rebale the eight that came out before I noticed, the old MF took those broken bales in at 4 MPH
