Oliver550Dave
Any hints or steps on removing the plunger on a NH 268 baler for bearing replacement? Hay wedges are out, stationary knife is out for sharpening, plunger connecting rod is disconnected from the crank, etc. I know the finger feed connecting lever also needs to be disconnected from the feeder drive pin on the plunger - I assume that disconnects by removing the nut on the drive pin that is torqued to 240 ft lbs. I know I haven't had that pin apart in the 30 years I have had this unit and it may not have been off before that! Again, any hints or cautions?? Is it safe to use an electric impact wrench to remove that nut? Does the adjustment assembly below that nut also need to be removed to facilitate removal of the plunger?
