Kow Farmer
I want to change the chain case oil in my Gehl 3610 skid loader. I was looking in my manual last night and it said I need 1 gallon per side and to use a good grade of engine in for replacement. Any recommendations of what oil viscosity to use? Also, I bought a used aftermarket cab heater. It is 12v, 2 speed fan. The fan has 2 inlet/outlet on back to plumb the coolant lines. I called the factory and they said I should plumb the heater in through both radiator hoses. Does that seem correct? I have a Northern heater made in Willmar Minnesota, which is somewhat close to me in location. I appreciate all your help from the past and in the future. Thank you sir.
Kow Farmer Kurt
Kow Farmer Kurt
