So I went out to mow some hay with the old 460. Made it one pass around and the rollers started to clog up and had lots of hay wound up on the upper roller. I stopped and cut the hay off and took back off again and it did it again. Then I cut that off and back up a little bit to make a turn and noticed the tension spring/cable for the roller was dragging the ground. Seems that the cable on the right side of the machine broke. I could not pull it back on place as it sits. I do not even know for sure how it should be routed even if I could get it back in place and hooked back up. Any body by chance have a picture of how the cable should be run??? There is a tube the spring seems to sit in but I have not been able to get the spring back into that either.
Thanks or any help you maybe able to give me
