Baler Thud Cured
showcrop
Well, Thanks to John Deere D and Bill VA, I got the MF 224 quieted down. I had set the front end of the bar that holds the plunger down, and tried to get the back the same. So today I loosened the bolts that hold it then tapped downward equally on all of them. The front was still at the same clearance and the rear was just a little lower. Then I ran it and it sounded normal again. I did check the needle frame and brake as Wolfman suggested to be sure that they were in spec and they were. Thanks guys!
