oldproudvet
I've an IH 1190 mower that I've used for years. For my beef cattle operation on a series of small pastures/hay ground it works very well. I've been trying to adjust the header float, the right side can only be picked up by my skidder, while the left side appears normal around that 60-70# that's recommended. My question: What do those 2 bolts that extend down into the 2 coil springs fasten into? It's impossible to see the ends, or to feel them. The parts book shows a nubbin that looks like it's fastened or wound into the top of the spring. The bolts turn, although they need a long 1/2" ratchet to twist them, but don't feel much different then the other side. The bolts are either stripped, which I doubt because then turn to tough, or the "piece" they are fastening to is turning in the top of the 2 springs. It just appears odd to me that both would be doing this. The header skid plate really flattens the grass on that side. Thank's for your 2 bits guys!
