Model of Bush Hog?
Sorry if things like this are beat to death but Im trying to find the model of my bush hog. There are lots of Massey Ferguson implements laying around but I dont want to assume this is a MF. The gear box is completely dry and I did run it for ~30min... So... It still turns freely but I imagine shes a short timer.
Anyway, anyone know the model? Maybe a manual? It appears to only have a drain and fill plug. Fill it up to the fill hole? Gonna see how quickly the fluid leaks out. Seems most recommend just filling it with grease.. Any recommendations on that?
Guess Ill fill it up with oil and see how long it takes to leak out. If its awhile Ill stay with oil since I think that lubricates the bearings better. If it lasts a day Ill put grease in it up to the fill hole.
Thanks
If it's a Bush Hog? go to bushhog.com and
look through their parts manuals.
If it's SOB (some other brand) you're on
your own.
The gearbox does look like it's BH? though.
Im not entirely sure but according to others its a bush hog. There is no information for a bush hog 105 on their website.
I flushed it out with diesel last week then pumped a little over two tubes of grease in it. Hard to tell if it was full since that stuff doesnt really flow, just piles up in there. Diesel freely flowed out of the input seal when I filled it up.... No grease came out though.
Cut for around 4 hours and it seems to be ok. Hardly got warm to the touch.
