kooima cracker plate for forage chopper
jim_uny
kooima makes a cracker plate for forage choppers. i have jd 3960. it says will do silage or earlage. when this is in use can you still use a screen, particularly for earlage ? has anyone used one of these and how where the results ?
kooima.com/shop/cracker-plate-3940-3950-series/
called kooima, they said one can not use screens at same time. thus i would only use for corn silage. they are sending me installation guidelines in a pdf.
If you buy one please post back this fall with results as I have thought about one for my 3940. We do both cornsilage and snaplage with our machine.Thanks Tom
tom - i bought a used one that had never been installed so its like brand new. will let you know. if you give me your email i will send a copy of installation pdf.
We used one in our 3950 two years ago. It worked well to crack more kernels. We pull the chopper and dump wagon with the 3150. With the cracker plate in it did slow us down. We were also running on the fine chop. HP was our limiting factor. Here's some pics
