JD 510 baler -lower belts - where to buy?
sam c
Greetings
I need to replace 4 of the 7 lower belts in a 510. I think these may be original as baler is in excellent shape.
Deere wants $180/belt. $1280 for all 7
Alternatively I can find generic belts on intert
A&I wants &108 per belt
I also found Amercas seed and belting for 140/belt.
I have never bought baler belting before. Are the JD belts better? Are the generics "good enough"
I am inclined to replace all 7 while I have it apart.
Do you have any guidance for me?
IMHO with the advanced engineering of later model rd balers I'd use the $$$$ for 510 lower belts as down payment on an open throat baler that will make a good bale of hay not just a bundle of hay.
If you're set on replacing the lower belts then I'd choose the A&I belts
I would not spend a nickel more than the lowest on a JD 510 round baler. The closed throat design they have is just one big headache.
