showcrop
I got the plunger disconnected and pushed back to where I could see the spacer that was pushed out by rust. Investigating how it is secured in place told me that I needed to do more than remove the plungerhead.
So off came the thrower and the back part of the chamber.
This one shows the bulging spacer
The third one shows the thrower with back of chamber set aside and the plungerhead on the floor
The fourth shows the spacer piece that came out in three pieces. It was a battle to get it out because the screws were recessed into the spacer with allen-heads INSIDE the bale chamber. It was a two man job to crawl in and find, clean out and get the allen wrench into the heads, then crawl under and find the nuts in places that you could not see and put a wrench on at the same time. But I got it done by myself. I was very fortunate that the screw heads held the allen wrench, and that the nuts weren't rusted onto the screws. I got the spacer welded back together, which was an hour by itself, then back in place and held by the one screw and nut which is easy to get at. I am now on break. The baler is an MF 224.
