Gehl 95 MX mill
55 50 Ron
Comments good and/or bad about this mill would be appreciated. Also do you know of a Parts Manual for it for sale?
Thanks Ron
(quoted from post at 12:22:25 05/27/16) Comments good and/or bad about this mill would be appreciated. Also do you know of a Parts Manual for it for sale?
Thanks Ron
The two worst things you can do to a mix mill is leave feed in it and let it set outside. If it's set out much at all especially with feed you'll be patching things. Unload augers tend to rust out especially in joints where feed sets and accumulates. I believe the Gehl has mill and some parts made by arts way.
95 is much better than the 65 I first had 40 years ago- 95 is hyd, right? I had a Lorenz 100 in between the 65 and 95. Sold the 95 to a neighbor about 10 years ago- he"s still using it. Definitely want to keep any mill shedded. 65 had the gears on the unloading auger, had to replace them once, not a fun job, but especially bad is the skipping as they wear out. Hyd is so much simpler.
About the only parts you're likely to find for one would be on a dealers shelves. A lot of those parts are already burned off from Gehl inventory.
Google German-Bliss. They carry parts for the Gehl mills and the parts manuals can be downloaded from their web site.
