Tree-Farmer
I borrowed an International 510 drill.
How do you adjust it?
I found the lever on the right side, front. It's set to 34.
I think I want to set it to 6. That's what the seeding chart calls for
I'm drilling Sudan Grass, says it should be 25 to 30 lbs per acre.
I loosened the nut on the lever, but I can't move the lever
Is there a trick to get the lever to move?
Any ideas?
Thank you
Any ideas?
Thank you
