AC 72 Allcrop ..... worth restoring?
polishdan
May have made a major mistake, bought a 72 and the lower grain elevator bottom housing crumbled when I opened the door. Can this assembly be removed in one piece to be refabricated ? Outside of that everything else can be cured or is in good shape.
Fix it! may be a lot of work,but will be qworthwhile.If it's above you,or you simply dont want to mess with it--Pass it on.....Dont junk it
If I can get the grain elevator out, I can fix it. Right now all I see is grinding rivets out and it will probably never be straight again ...... there must be a trick, please help.
Got in contact with Allcrop and he gave me the procedures that will make disassembly and restoration possible. thanks
