JD 430 Baler
I have a few belts that need to be re spliced and trying to figure out the best kit to buy. I would like something that can be used in the field if needed since that always seems to be the case of being away from the house when something needs repaired.
I know that there are alot of kits but what is a good easy one to use. Thanks for the help.
I guess from what I can tell I think I would like the alligator clip design better than the clipper style.
From what I have been told they hold up better. This is the first time I have had to repair a belt so I am not sure.
Thanks for the help
The best thing you can do for your baler is to resize ALL the belts back to the factory length. If they are short than at least make them all match. As for lacing I use the Mato. I have tried the Alligator and it does not seem to like going around smaller rollers an soon comes apart when I tried it.
Forgot the photo
