If I adjust the spray rig pressure to it's lowest setting, the adjustment knob could fall off.
Is there any way to restrict the pressure, so that I can use the pressure valve for lower pressures. With the valve backed all the way out, and all 3 boom sections spraying, it will usually run at 10 to 15 psi. That makes me have to travel at B-2 or B-3 shifting. This can get a little rough in pastures.
I'm thinking to put a washer or restriction in a line, but where to put it ?
