International Model 70 Plow bearings needed
I am looking for part numbers or supplier for tailwheel bearings. Model 70 4 bottom
Rear hub is an F&H with casting number 161892R1
Uses two tapered bearings, also need a seal.
thanks in advance for any leads. The part numbers on the old bearings are not legible.
If you have one complete inner race and one complete outer race about any decent shop can match you up with the right bearing. Otherwise the outside diameter and inside diameter will be all you need.
Thanks for all the replies. I am looking to see if anyone knows of an application guide by model number or casting number for this hub.
