Who made this hay rake?
Is that a 3 point rake?? If it is it looks a lot like the Ford 3 point rake I have. I hate the rubber mount teeth on it since they cost around $4 each which cost a lot to replace them
It's a drawbar rake I'm pretty sure. Guy has it for sale for $300 but I've never seen one like it.
I would if I could find them but I have yet to find steel mount teeth that fit some time it is not all that simple to do thing and yes this Ford rake had the rubber mount teeth from the get go
It looks like a ford rake my uncle bought in the late 60s. I raked quite a bit with it.I seem to remember that if you turned to fast to the left the little wheel would come off the ground.Seemed like fun to a teenager at the time. It made a clanging noise from the first day. I never liked it. I couldnt believe how quiet a new holland was when I first started using it.
Designed as a 3 point rakw and the wheels were caster wheels. when design converted to a pull type ground drive to use a small wheel not enough power to run the rake so as it was easiest way just put the one big wheel on for powering, most rakes will have 2 wheels powering the real, that has only one.
