hillsidehogz
New User
I found this disc yesterday for sale up the road from me for $300. It has bent lever assembly's but working ok. It has a broken spacer spool piece and axle looks to be bent slightly on rear gang. Front gang has something loose or broke on inside between disc and bearing allowing disc to wobble. The 3pt hitch needs welded back up on back left where the round tube ties in to the flat piece of iron. I don't know how the bearings are either.
He used the disk like that last fall and said it still worked great What are the odds of this disc being straight enough to fix as it sits without getting to deep into cost of repairing you all think? Should I keep looking for a better treated disc also and save myself from frustration? And last, I really wanted a #25 disc harrow but have read that the #22 was the original and later it was called #25, truly being same disc, is that true or not?
Thank you all in advance.
