White 5100 gear box
I want to double check myself on which is drive ,driven, and counter triple shaft. Looking from the back of the planter. The one on the right has 3 sprockets(counter triple?) the to the left of it has four(drive?) and the set of gears on the shaft to each unit is (driven?)
OK, Standing behind the planter; the rear shaft with 2 cluster gears is the countershaft. The gear on the right is the drive gear, the one on the left is the driven gear(countershaft cluster gear), the shaft inside that is hard to reach is the feed shaft(to the planter units). Clear as mud?? Do you have a book ordered?? How are you coming up with sprocket combinations to set population?? Chris
Ok I got. I was going with the seed chart on the of the seed box. I wanted to double check and make sure I knew which gears where which.I just just a book, had a hard time finding one. Thanks
