JD 55 plow parts
I have a JD 55 3/16 that needs new plow points/lays/shares, what ever you guys call them geographically. Are these available new?
I also have a JD 55 3/14 that needs some of the spring loaded latch parts that goes up to the handle that controls depth. Any used parts out there?
Depends on what style bottom it has on it now. HS throw-aways are available through several sources. Ploworx has some of the older style parts.
Ploworx
If your JD 55 plow has the 16 inch HS bottoms, you can still get shares from your local JD dealer. The share would be part # A10007 which are 16 inch 3 hole shares. I have several JD plows that I still use and I always get my shares from JD. JD Online Parts lists them for $34.51. You might find then cheaper from other sources. Hope this helps. Al
