John Deere AW discs
Brendon Warren
I'm looking for an aftermarket source for discs, three gang bearings, and a four inch spool for my 14' AW discs. Any part # or suggestions are appreciated.
Shoup are the best! but if your old disk just happens to have the old greaseable iron 'box' bearings(boxings),you may be stuck with 'mother Deere' for those.Shoup for everything else.
I looked through shoup's site and found it a little tricky. I couldn't find the spool I wanted. I think it would of been better with a catalog. I did find everything I needed at one called Sloans Express. The bearings were $17 dollars less a piece but disc blades were a few dollars more. The only problem with them was the shipping. For shipping everything including 10 blades was $145 freight. If I ordered everything but ordered only seven blades shipping was $26 ups. Ill get by with seven and order more if I decide I need them at that rate. I guess I'll know soon enough if I made the right choice. I hate to ask for advice and then not follow it. Thanks.
I've been using Ag Supply for the past few years, and they have been pretty good at getting me the right parts. They had a bolt, bearings and spacer out the next day when I called them in the morning, UPS. Little gal knew her discs....
