I'm rebuilding this old harrow. It had lots of wear and abuse during it's youth. But now everything is taken apart and ready to reassemble.
Each disc assembly has 6 discs mounted on a 7/8" square shaft with three spacers and two spindles. The spindles fit in the split cast iron bushings mounted to the harrow frame.
Found a lot of hardened dirt and grease in the iron bushing grooves.Once cleaned out, the spindles which rotate inside these bushings are incredibly loose yet don't show that much wear.
Were there some kind of replaceable liners which fit inside the iron bushings? Like a babbit or bronze bearing liner? I see no evidence of anything like that but can't imagine that it's designed with 1/8" clearance between bearing surfaces. And nothing is sealed so the grease will just push out.
