dschaefer55
Need help. I am looking for new spike tooth harrow teeth. Each tooth has four sides. Teeth are solid metal & attach with 7/16" nut & threads. I've looked online, local stores and can't find any new ones, my harrow teeth are about wore out. Teeth mount through holes in a pipe for threaded end of teeth. 8 teeth per bar, one longer threaded tooth per bar to go through bracket and pipe. Two brackets near each end of pipe, other bracket attaches with regular bolt. 5 bars per section are 55" long by 41" long. Bars are 9" apart. Harrow is great for smoothing out driveway behind disk and tilling in field. Would like to find whole new sections if possible. But need replacement teeth for sure I live in Minot, North Dakota. I have attached pictures
