Rods for plow lever arms
Farmallb
I saw where someone was remaking these rods that went from the lever handle down to the stud that went into a slot in the plow set gauges, Anybody know if anybody is still doing this?
Yep, they got it. Thanks. Got a 1 16 and a 2 14, both IHC that need rods. Done with baleing wire lol.
If you bend them correctly you won't need clamps.If you feel you need clamps, just sandwitch the two rod ends between two washers with a bolt and nut.
Loren
It's still nice to have them in two pieces so you can fine-tune the trigger lever travel, or if you decide to adjust the lever length. I've used cable clamps from the hardware store with success.
