Coulter Disc Blade help needed
I have a Perry gopher poison machine that I need to replace the coulter blade for but I'm having trouble finding one. It is 18" diameter with a 4 bolt hub pattern, 2 3/16" center hole. It has a fluted blade now but either that or a simple plain coulter would work fine. Do you guys know a good source for coulter blades I can call because what I see online doesn't suit my needs.
Thanks
I needed an 18" blade for the rear guide on a couple of old Ferguson disc plows that I repaired.
I bought the proper size coulter blade, centered the old blade on top of the new blade, separated the two blades with 1/4" nuts,
Used the torch and cut out the holes to fit, worked like a charm,
The new blades fit right on the hubs and all attachment bolts lined up properly
Worth a shot if you can not find the blade you need
What's the diameter of the circle for the bolt holes. I jave these
OEM blade is 18" OD, 2 3/16" center hole, hub is 3 3/8" bolt circle with 4 holes at 5/16" dia for 1/4" bolts. It is odd ball as they come. I can't find it anywhere so before I saw you post about this place making custom blades I bought one as close as I could and had a local machine shop drill the holes for me. I appreciate your help. I will surely keep them in mind.
