Lustran Planter Plate Repair
K-Mo
Has anyone had success "gluing" a cracked Lustran planter plate? If so, what type of adhesive?
Thanks,
K-Mo
I have ran them with one side cracked completely apart for long time without any problems. Does your plate have the little hole that only goes in a bit on the bottom or not. Real old plates did not have that but newer ones did, that is a wear guide and if it is about gone the plate is wore out and needs to be replaced as it is getting too thin.
K mo,
If you are in corn and bean farming country, check out the oldest farmers still farming. Or see a seed dealer, or a guy who was a seed dealer....they will plenty of them...and for no cost as they were free to them in years past. Chances are they have a bunch of IH and JD plates hanging on nails in the barn or machine shed. Plates are so plentiful why fool with trying to fix one.
Other's advice is correct: Call Lincoln AG at 1-402-464-6367. You pay for what you get (a poor stand with broke equipment).
LA in WI
