JD MX8 Bush Hog - need help
The pro slip clutch keeps coming off the gear box shaft - why? I have put it back on 3 times. Tighter the bolt and within a few minutes after the
pot is engaged, she flys off. I have tighter the bolt so tight once - I twisted the bolt in half. What do you guys think? How can I solve this?
Ok, I looked over the JD MX8 parts. I am pretty sure it is the Walterschied slip clutch. No what? What about the 14mm bolt?
