Help identifying a disc.
jjjg02
New User
Can anybody put a name on this disc?
Massey Harris, before they put models to them. It is missing the crank to adjust angle and that would be where the MH was in the casting the crank whent through. Had one I got out of scrap yard bercause I did not want to see it cut up. I rebuilt it last year and sold it to Amish. I am guessing early 30's. Definatly not Dearborn.
Thanks Leroy. I have the crank handle for it, but it was bent and froze up so I'm fixing it up. Its missing a couple disc also any idea on where to find new ones? I knew it was old but didn't think 30's.
I am not sure if I have any pictures around or not,Took some to remember how it went together but not sure if they are still around and don't remember of taking any after it was done. I just used blades that I bought used at auction. Machinery jocky happened to have new wood bearings that fit. or I would have had to make them.
Not sure if this has the wood bearings I haven't gotten into that far, it has grease fittings on the bearing housing's.
Leroy do you happen to know the model of the disc? Maybe even the part number for the bearing I saw woodex makes them?
