John Deere BWA parts help
I need some help repairing my BWA disc. I need to know what cylinder length and dia. I need to restore that function to the unit as well as the hose dia and length was on the unit. I'm not looking forward to the inn and off this spring to manually crank the lift and drop into the disc to do my fields again. Thank you frontage help.
Greg
A standard 8" stroke x3" bore 'farm' cylinder. A couple of half inchx10' hoses should be plenty long
(quoted from post at 00:00:55 02/28/16) A standard 8" stroke x3" bore 'farm' cylinder. A couple of half inchx10' hoses should be plenty long
Thank you,
Any idea how to identify what hose fitting I need to connect it to my. JD 2555 remote?
ISO male tip either ORB of NPTF depending on hose threads
So,it's new enough that it uses the ISO/pioneer? I was thinking it used the old JD tip.I know the 'switch' was
somewhere in that 'era',but I thought it was on the new series(5400,6400,7800 etc)
(quoted from post at 12:12:45 02/28/16) So,it's new enough that it uses the ISO/pioneer? I was thinking it used the old JD tip.I know the 'switch' was
My JD was built in 1988. I haven't checked the fittings to see if there are any markings, I don't remember seeing any.
